Using ActiveX to exchange data
Embed provides the ActiveX read and ActiveX write blocks for real-time, interprocess communication. Using these blocks, you can exchange data with other applications that support ActiveX™. The ActiveX read block receives data from the Active X container; the ActiveX write block sends data to an ActiveX container.
Required files
To register properly, the Embed ActiveX control requires the following files:
•      MFC42.DLL
•      MSVCRT.DLL
•      OLEAUT32.DLL
•      VSMIPCD.DLL
The first three files are in your Windows system directory. The last file is in your <install-directory>.
