Transition selection algorithm
For every state, there is a set of outgoing transitions, of which no more than one will fire. The order of evaluation of transitions is determined by the following:
•      Outgoing transitions belonging to the given region and with triggers.
•      The transitions must retain their order in vertex's outgoing transitions list.
•      External compound transitions with triggers outgoing from enclosed states.
•      Outgoing transitions belonging to the given region and without triggers.
•      External compound transitions without triggers outgoing from enclosed states (for non-simple states).
