The Save Embedded command
If the diagram contains one or more embedded diagrams, any changes you make to those diagrams are not saved until you use one of the following File > Save Embedded command options:
•      Save Embedded Blocks to Source Files: Saves the changes back to the source diagrams.
•      Save as a Single Combined File: Saves the changes to the current diagram only. All links between the embedded blocks and the source diagrams are broken.
