System-wide event function - vsmEvent()
This function is called by Embed to notify the DLL of interesting simulation-wide events.
LPSTR PASCAL vsmEvent(int msg, int wParam, long *arg);
Message
Function
VSE_ALLOC_CODEGEN_INTERRUPT
Sent at start of codegen so Interrupt Enable string is emitted and configured as set in diagram.
wp:       Interrupt configuration string
lp:         Interrupt source name string
VSE_FILE_READ
Sent after diagram is read.
wp:       0
lp:         0. Return ignored
VSE_FILE_SAVE
Sent before diagram is saved.
wp:       0
VSE_GET_CODEGEN_DECL_STR
Sent once per DLL at the start of code generation. Returns a char * string of text to be inserted into the generated code at file scope before block code generation messages are processed.
VSE_GET_CODEGEN_FUNC_DECL_PREFIX
Returns a char * string of function declarator prefix.
VSE_GET_CODEGEN_FUNC_POSTAMBLE
Returns text string of code to insert at end of function.
wp:       0
lp:         0
VSE_GET_CODEGEN_FUNC_PREAMBLE
Returns text string of code to insert at start of function.
wp:       0
lp:         0
VSE_GET_CODEGEN_INCLUDE_STR
Returns a char * string of include files.
VSE_GET_CODEGEN_INIT_STR
Returns a char * string of text for initialization.
VSE_GET_CODEGEN_INIT_PROCESSOR_CLK
Returns string for CPU clock initialization.
VSE_GET_CODEGEN_INTERRUPT_CLR
Returns a char * string of C code that clears an interrupt.
VSE_GET_CODEGEN_INTERRUPT_ENABLE
Returns a char * string of C code that enables an interrupt.
VSE_GET_CODEGEN_INTERRUPT_ENTRY
Returns a char * string of function interrupt entry.
VSE_GET_CODEGEN_TIME_STEP_STR
For internal use only.
VSE_GET_CODEGEN_TIMER_FUNC_END_STR
Returns a char * string of C code that is inserted at end of main RTOS interrupt handler.
VSE_GET_CODEGEN_TIMER_START_STR
Returns a char * string of C code that is inserted at the start of main RTOS interrupt handler.
VSE_GET_OSDETAILS
Returns current OS string (like “stretch” or “buster”).
wp:       N/A
lp:         N/A
VSE_GET_PARAM_DESC
Returns descriptor for DLL configuration dialog that has no block associated with it. Syntax is identical to WM_VSM_GET_PARAM_DESC.
VSE_GET_TOOLCHAIN
Returns current toolchain string (like “gcc” or “armcc”).
wp:       N/A
lp:         N/A
VSE_POST_SIM_END
Embed has stopped, either from user stop or time expiration.
VSE_POST_SIM_START
Embed has initialized all blocks and is about to start.
VSE_PRE_CODEGEN_START
Guarantees to be send before any other codegen message. Args are ignored.
VSE_PRE_SIM_START
Embed is about to start a simulation but has not initialized any blocks.
VSE_SET_CODEGEN_OPTIONS
Passes codegen link option to target codegen DLL.
wp:       0
lp:         0
VSE_SIM_RESTART
Embed is restarting due either from user restart or an auto-restart.
VSE_TARGET_CMD
If wParam==0: returns 1 if user can download; wParam==1, do download; wParam++2, display Download dialog box.
VSE_TIME_STEP
Simulation has completed a time step.
VSE_VSM_ACTIVATE_VIEW
Sent on diagram activation.
wp:   0
lp:     Window handle of parent view
VSM_WINDOW_HANDLE
Handle to Embed main window.
arg:  Window handle
WM_COMMNOTIFY
Comm port data is ready.
WM_DESTROY
Embed is exiting.
WM_VSM_WINDOW_HANDLE
arg:  Window handle
