System characteristics
In designing each compensator, the following system characteristics hold true:
•        LM = Log magnitude, base 10
•        Cross-over frequency of open-loop Bode LM plot
•        Phase margin of open-loop Bode phase plot
•        Time constant, s
•        Damping ratio
ch6 system characteristics 1
The open-loop Bode frequency response can be used to approximate closed-loop system behavior, provided the open-loop frequency response satisfies three conditions:
•      The gain at low frequencies is relatively high for low steady-state errors
•      The gain at high frequencies is relatively low for disturbance attenuation
•      The slope of the Bode plot is approximately
When the above conditions are approximately satisfied, the following correlations are valid:
