The Starting Values section lists the starting values for
the problem variables and the computed values of the constraint functions and
the objective function. The functions (constraints) table shows the values
computed using the starting values of the variables. The notation used in the
Status column, for variables and constraints, and in the Type column for
constraints, is described in the following table.
Status |
Description |
Type |
Description |
UL |
Constraint or variable is at its upper bound |
EQ |
Equality constraint |
LL |
Constraint or variable is at its lower bound |
LE |
Upper bound constraint |
EQ |
GE |
Lower bound constraint. |
Constraint is violated, value is less than lower bound or greater than upper bound |
RNGE |
Lower and upper bound constraint |
FREE |
Variable has no lower bound and no upper bound |
OBJ |
Objective function |
FX |
Fixed variable, lower bound equals upper bound |
NA |
Constraint function ignored because it has no lower bound and no upper bound |
Starting Values
Functions
Function |
Initial |
Lower |
Upper |
No. |
Name |
Status |
Type |
Value |
Bound |
Bound |
___ |
________ |
______ |
____ |
_______ |
_______ |
_____ |
1 |
G |
OBJ |
0.178051 |
2 |
G |
RNGE |
0.249988 |
0 |
0.4 |
Variables
Variable |
Initial |
Lower |
Upper |
No. |
Name |
Status |
Value |
Bound |
Bound |
___ |
________ |
______ |
_______ |
_______ |
_____ |
1 |
X |
1 |
-10 |
10 |
2 |
X |
1 |
-10 |
10 |
