Add-On Module |
Description |
Embed/Core Source Code Library |
Contains pre-compiled functions for core blocks that are not translated into inline code. Target is the PC. Available only for Embed. Not available for academic (EDU) licenses. |
Embed/Target Source Code Library |
Provides source code for target-specific blocks not translated into inline code. You choose the target: Arduino Leonardo, Mega, Uno; Linux Raspberry Pi Zero, Zero W, 1A+, 1B+, 2B, 3A+, 3B, 3B+, 4B; STMicroelectronics STM32 F0x, F103x, F3x, F4x, F7x, G0x, G4x, H7x, L4x; Texas Instruments ARM Cortex M3, C2000, Delfino, MSP430, Piccolo. Available only for Embed. Not available for academic (EDU) licenses. |
Embed/Digital Power Designer |
Provides high-level blocks for simulation and code generation of power supply and digital power components and controls. Available only for Embed. |
Embed/Comm |
Simulates end-to-end communication systems at the signal level using 200+ communications, signal processing, and RF blocks. Available for Embed SE and Embed. The blocks are for simulation only. |
