Solving the optimization problem
To solve the problem
•      From the Toolbar, click on the  toolbar button to start the optimization.
You will observe the following after 28 simulation runs (reference $runCount in the diagram):
•      The cost block has changed from 0.178 to 5.82e-3
•      The parameterUnknown block, in the upper part of the diagram, has changed to 2.38
•      The parameterUnknown block, in the lower part of the diagram, has changed to 2.29
In addition, a report is written to VSMGRG2.TXT that provides more information on the optimization process.
