Setting up state chart variables
The Data Browser tab for the State Chart Properties dialog box lists the current variables and variable attributes for the state chart. You can add and delete variables, and update their attributes through this window.
To add and delete variables
There are several ways to add and delete variables.
•      In the Data Browser window, use the following buttons:
Button
Function
Add Variable button
Adds a variable
deletevariablebutton
Deletes the selected variables
•      To add input and output variables, use the Add Connector button toolbar button.
state chart blk with 2 inputs and Add Connector
•      To delete input and output variables, use the Delete Connector button toolbar button.
To edit variables
•      In the Data Browser window, double-click over the attribute to be changed.
•      For Type, Scope, and Pin, a drop-down menu appears in which to choose an attribute value.
•      For Name, Default Value, and Comment, a box surrounds the variable attribute indicating Edit mode. Enter the new attribute value and press ENTER.
