Setting up and running Apache Kafka®
Apache Kafka is a distributed streaming platform with three key capabilities:
•      Publish and subscribe to streams of records, similar to a message queue or enterprise messaging system
•      Store streams of records in a fault-tolerant durable way
•      Process streams of records as they occur
Embed provides a Kafka Consumer and Kafka Producer block for publishing and subscribing to streams of records. To use these blocks, you must first set up Apache Kafka by downloading the following software:
•      Server JRE according to your OS and CPU architecture (https://www.oracle.com/java/technologies/javase-jre8-downloads.html)
•      7-zip that is used to extract ZooKeeper and Apache Kafka (https://www.7-zip.org/download.html)
•      ZooKeeper (https://zookeeper.apache.org/releases.html)
•      Apache Kafka (http://kafka.apache.org/downloads.html)
For step-by-step for setting up and running Apache Kafka, see https://dzone.com/articles/running-apache-kafka-on-windows-os.
