Setting the constraints
The upper and lower bounds for the globalConstraint block are established in its dialog box. You only have to assign these values once; after that, the upper and lower bounds are remembered.
To set the upper and lower bounds
1.    Right-click the globalConstraint block.
2.    In the Upper Bound box, enter 0.4.
3.    In the Lower Bound box, enter 0.0.
4.    Click OK, or press ENTER.
