Setting root locus resolution
You can define the number of steps in the gain sweep, which in turn determines the point count resolution of the root locus gain.
To define the resolution for a root locus plot
1.    Choose Analyze > Root Locus Options.
2.    In the Step Count box, enter a value that indicates the step size for moving the gain. For a finer resolution, increase the step count. The default value is 50.
Note: The larger the step count value, the longer it takes to compute the new root locus plot.
3.    Click OK, or press ENTER.
4.    Choose Analyze > Root Locus to generate a root locus plot with the specified step count.
