Resetting bitmap images
Bitmaps that are placed on blocks may appear distorted in size under the following conditions:
•      You open a diagram and the current screen resolution is not set to the resolution when the bitmaps were originally created
•      You change the font size in Embed
To remove bitmap scaling
•      Choose Edit > Reset Bitmap Scaling.
