The Problem Description section displays the current versions of Embed and GRG2, the specific GRG algorithm on which Embed is based, along with the date and time of the run.
The number of variables and the number of functions (the sum of the number of constraints and objective function) are displayed, along with an indication of whether the problem is one of minimization or maximization.
When you change algorithmic parameters, they are also listed here.
The information in this section should confirm that the problem has been set up correctly.
GRG2 95.10 Report: Date Tue March 2 10:00:00 2021
Problem Title: Embed SE 2021, Optimization by Embed SE / OptimizePRO
Problem Parameters:
Number of variables is 2
Number of functions is 2
Objective function will be MINimized
