Printing a block diagram
The File > Print command lets you choose a printer and select printing options, such as the number of copies, the layers to be printed, and so on. You can also set up printer options by clicking on the Setup button in the Print dialog box. Use the File > Page Setup command to specify margins, headers, and footers.
To print a block diagram
1.    Do one of the following:
•      From the toolbar, choose .
•      Choose File > Print (CTRL+P).
2.    Do one or more of the following:
To print
Do this
Multiple copies
In the Copies box, enter a number.
The current level of the diagram
Under Print Range, activate Current Level.
The current level and below
Under Print Range, activate Current Level and Below.
All levels of the diagram
Under Print Range, activate All.
Each level of the diagram on a separate page, and when necessary, reduce diagram text so the level fits on a single page
Activate Fit to Page. Because Embed prints each level with the minimal reduction possible, the levels of a multi-level diagram may be sized differently.
Embed may not be able to print extremely large diagrams when Fit to Page is activate. In these cases, Embed gives you the opportunity to abort the print operation. If you choose to continue printing, Embed prints as much of the diagram as will fit on the page.
What is currently displayed on the screen
Activate Print Current View. Embed prints what you see on the screen, starting at what is in upper left corner of the screen.
Each level using as many pages as necessary to print it without resizing
Activate Tile Pages. The margin settings are honored for each page.
A version of the diagram to a file to be printed later or to be used in another program
Activate Print to File and then click OK, or press ENTER. In the ensuing dialog box, specify a name for the diagram you want to print.
