Preparing diagrams for constrained optimization
In preparing your diagrams for constrained optimization, remember that every time a parameterUnknown block or a globalConstraint block is pasted into a diagram, the upper bound is set to 1.e30 and the lower bound is set to -1.e30. This means that unless you reset these bounds, the decision variable (or constraint) is unconstrained.
The following conventions are used to set the upper and lower bounds:
•      1.e30 represents infinity (+∞)
•      -1.e30 represents minus infinity (-∞)
The table below shows how to set values of the upper and lower bounds:
Bound Type
Math
Lower bound
Upper bound
Free (no bounds)
-1.e30
1.e30
Lower bound only
[ a, + ∞)
a
1.e30
Upper bound only
( - ∞, a ]
-1.e30
a
Lower and upper bound
[ a, b ]
a
b
Equality
[ a, a ]
a
a
