Measurement Computing boards
All boards supported by Universal Library software are supported by Embed. Try to avoid using the newer USB/PCI-25xx series because they are optimized for burst mode performance. They get only about 100Hz performance for HIL single point read/write mode.
Single point performance of USB-1208LS is about 50Hz, USB-1208FS is 250 Hz and USB-1208HS is 1 kHz. These figures are divided by channel count.
The USB-1608HS has 8 separate ADC units and can send all channels in one USB packet, so performance of 1 kHz is not affected by channel count.
Below is the complete list of Measurement Computing boards supported by Embed.
Analog I/O
Analog Output
Digital I/O
USB Boards
PCI-DAS6071
PCI-DAC6702
PCI-CTR20HD
USB-1208FS/LS
PCI-6013
PCI-DDA02/16
PCI-CTR10
USB-1208HS-2/4A0
PCI-6014
PCI-DDA02/12
PCI-CTR05
USB-1408
PCI-DAS6070
PCIM-DDA06/16
PCI-DUAL-AC5
USB-1608G
PCI-DAS6040
PCI-DDA04/16
PCI-DIO96H
USB-1608LS
PCI-DAS6025
PCI-DDA04/12
PCI-DIO96
USB-2533
PCI-DAS6023
PCI-DDA08/16
PCI-DIO48H
USB-2537
PCI-DAS4020/12
PCI-DDA08/12
PCI-DIO24H
USB-2523
PCI-DAS1602/12
PCI-DAC6703
PCI-DIO24/S
USB-2527
PCI-DAS1200/JR
PCI-DIO24/LP
PCI-DAS1200
PCI-DIO24
PCI-DAS1002
PCI-QUAD04
PCI-DAS1001
PCI-PDISO8
PCI-DAS1000
PCI-PDISO16
PCI-DAS08
PCI-INT32
PCIM-DAS16JR/16
PCIM-DAS1602/16
PCI-DAS6402/16
PCI-DAS64/M2/16
PCI-DAS64/M1/16
PCI-DAS6052
PCI-DAS6036
PCI-DAS6035
PCI-DAS6034
PCI-DAS6033
PCI-DAS6032
PCI-DAS6031
PCI-DAS6030
PCI-DAS6014
PCI-DAS6013
PCI-DAS1602/16
PCI-DAS-TC/BRD
