Matrix Gain for Simulink
Simulink Category: Math blocks
Embed Block Equivalent: [] X [] compound block
You must check input vector dimensions. Scalar to vector transformation produces a row vector. Usually it is not important, but matrix operations require an exact shape, either row or column, depending on the operation. See the From File command for information on using the scalarToVec block to add input connectors.
