Look-Up Table for Simulink
Simulink Category: Functions and Tables blocks
Embed Block Equivalent: map block
This block is implemented through the Embed map block. It requires an additional map file. The translator automatically generates the file. However, if arguments for the original block are complicated MATLAB expressions, the original expressions are written to a file that you must convert manually.
