You can link to external files, diagrams, and URLs using the label block. This is particularly useful for adding a requirements traceability link to the diagram.
To create a link from a document or website
1. Go to the Microsoft-compatible document, such as a Word document, Excel spreadsheet, or PowerPoint presentation document or the webiste.
a. Select the text or URL to which the diagram will link.
b. For documents, create a bookmark of the selected text.
c. Save the document.
d. Select Edit > Copy (CTRL+C).
2. Open the diagram that will contain the link.
a. Insert a label block into the diagram and right-click it..
b. Activate Hyperlink.
c. Click Paste Hyperlink.
d. Click OK and save the diagram.
The label contains the link information, including the path to the linked document or URL and whether the link is active. When you click the label block, the document or website opens.
To create a bi-directional link between two diagrams
1. Open diagram1.
b. Enter a label name, activate Hyperlink, enter a unique name in the Bookmark text box, and click Copy Hyperlink.
c. Click OK and save the diagram.
2. Open diagram2.
b. Enter a label name, activate Hyperlink, and click Paste Hyperlink.
The Link to file, diagram, or URL and Bookmark text boxes are populated with the link information from diagram1.
c. Click Copy Hyperlink.
3. Open diagram1.
a. Right-click the label block.
b. Click Paste Hyperlink.
The label blocks contain the link information of the two diagrams. When you click the label block in diagram1, it opens diagram2 at the linked location, and vice versa.
The following 3 x 7 Excel spreadsheet lists sample requirements for an automotive speed control system: column B lists the requirements and column C describes the requirements. In this example, cell B2 will be linked to the name that appears on the label block in the Embed diagram and the contents of cell C2 will be highlighted when you click on the label block.
1. In your Embed diagram, go to Blocks > Annotation, and insert a label block. If this is a new diagram, save it.
2. Go to your requirements spreadsheet, right click cell B2, and select Link from the pop-up menu.
3. In the Insert Hyperlink dialog box, select the requirements spreadsheet and click Bookmark. Note that the contents of cell B2 (speedControl.stop) is displayed in the Text to display box.
4. In the Select Place in Document dialog box, enter C2 (rather than B2) to link to the description of speedControl.stop and click OK.
5. In the requirements spreadsheet, cell B2 is highlighted.
6. Right click cell B2 and select Copy from the pop-up menu.
7. Return to the Embed diagram and right click the label block.
8. In the Label Properties dialog box, activate Hyperlink and click Paste Hyperlink.
The Label Properties dialog box is updated with the hyperlink information.
9. To display the description of speedControl.stop, revise the bookmark location in Named location (bookmark) in file to Sheet 1!C2 and click OK.
10. In the Embed diagram, the label block appears as a hyperlink named speedControl.stop. When you click speedControl.stop, the requirements spreadsheet opens with a border around cell C2.
