The Mathcad Properties dialog box lists the size of your embedded Mathcad document, and allows you to control the general appearance of the document in your diagram. You can also use the Mathcad Properties dialog box to scale the corresponding embedded document. This feature is described under To scale an embedded Mathcad document using the Mathcad Properties dialog box.
To access general information about an embedded Mathcad document
You can display the size and location of the embedded Mathcad document.
1. Right-click the embedded Mathcad document.
2. In the drop-down menu, choose Properties.
3. The Mathcad Properties dialog box appears.
4. Click the General tab.
To control the appearance of an embedded Mathcad document
3. Click the View tab.
4. Do the following:
To |
Do this |
Display the contents of the embedded Mathcad document |
Activate Display As Editable Information. |
Display a Mathcad icon |
Activate Display As Icon. Click Change Icon to select the type of icon to be displayed. |
5. Click OK.
