Error and warning messages
Error
A composite state can have at most one (deep) history vertex
A composite state, even orthogonal, may have no more than one history pseudo-state. A history pseudo-state stores the history for the whole composite state, not just for the region where the pseudo-state resides.
A (deep) history vertex can have at most one outgoing transition
A (shallow or deep) history pseudo-state must have just a single outgoing transition targeting a state in the same region. This transition is called a default history transition.
A fork transition segment must always target a state
The transitions outgoing a fork pseudo-state must target states (but not pseudo-states) in different regions of the same composite (orthogonal) state.
A join transition segment must always originate from a state
The transitions incoming a join pseudo-state must originate from states, not pseudo-states, in different regions of the same composite (orthogonal) state.
All transitions incoming a join vertex must originate in different regions of an orthogonal state
The transitions incoming a join pseudo-state must originate from states (but not pseudo-states) in different regions of the same composite (orthogonal) state.
All transitions outgoing a fork vertex must target different regions of an orthogonal state
An entry point must have a single transition to a vertex within the same region
An entry point pseudo-state must have just a single outgoing transition targeting a vertex in the same region.
An initial vertex can have at most one outgoing transition
An Initial vertex can have just a single outgoing transition targeting a state in the same region.
An initial vertex must have a single transition within the same region
Argument for InState must be a quoted string constant
The InState function must have an argument that is a non-empty string constant.
A submachine state can have at most one (deep) history vertex
A submachine state may have no more than one history pseudo-state.
A transition outgoing a (deep) history vertex must target a vertex within the same region
Default history transition may result in an endless loop
The transition, outgoing the history state, targets directly or indirectly the same history state, what may result in an endless execution loop.
Empty string cannot be used as argument for InState
Incomplete statemachine: a fork vertex must have at least two outgoing transitions and exactly one incoming transition
A fork pseudo-state may have just a single incoming transition and at least two outgoing transitions. The transitions outgoing a fork pseudo-state must target states (but not pseudo-states) in different regions of the same composite (orthogonal) state.
Incomplete statemachine: a join vertex must have at least two incoming transitions and exactly one outgoing transition
A join pseudo-state may have just a single outgoing transition and at least two incoming transitions. The transitions incoming a join pseudo-state must originate from states (but not pseudo-states) in different regions of the same composite (orthogonal) state.
Missing ')’
The number of ( and ) does not match.
Missing argument for InState
Missing argument for SendT
The SendT function must have an argument that can be evaluated to a trigger.
No initial transition found in the enclosed region(s)
One or several regions of a composite state or a submachine state have no initial transition. A region without an initial transition can exist but in this case the region can become active only through an incoming transition to one of its enclosed states.
No initial transitions found on the top level
The state chart has no initial transition.
The outgoing transition from an initial vertex may have a behavior but not a trigger or guard
An initial transition may not have any triggers or guards. In general, any transition outgoing a pseudo-state may not have a trigger.
There can be at most one history vertex in a region
Only one history pseudo-state is allowed in a region.
There can be at most one initial vertex in a region
Only one initial transition is allowed in a region.
The transition incoming a join vertex may not have triggers or guards
Transitions incoming a join pseudo-state, may not have any triggers or guards even though they originate from a states and not pseudo-states.
The transition outgoing a fork vertex may not have triggers or guards
Transitions outgoing a fork pseudo-state may not have any triggers or guards. In general, any transition outgoing a pseudo-state may not have a trigger.
Transitions outgoing choice vertices must have guards
Every transition outgoing a choice pseudo-state must have a guard. It is recommended that one outgoing transition has the predefined else guard.
Transitions outgoing pseudostates may not have a trigger
Any transition outgoing a pseudo-state may not have a trigger.
Warning
Initial vertex has no outgoing transitions
Usually initial transitions have a single outgoing transition.
