Editing and updating Mathcad documents
You can edit an embedded Mathcad document directly from Embed, or you can invoke Mathcad as a separate, stand-alone application. To update the embedded Mathcad document and return to the Embed environment, simply click outside the Mathcad document. For information on using Mathcad, see your Mathcad documentation.
To edit an embedded Mathcad document directly from Embed
1.    Do one of the following:
•      Double-click the embedded Mathcad document.
•      Right-click the embedded Mathcad document.
2.    From the drop-down menu, choose Mathcad Object > Edit.
Embed opens a Mathcad window with the Mathcad document.
3.    Make the changes you want.
4.    Click outside the Mathcad document to update the Mathcad document and return to Embed.
To invoke Mathcad as a stand-alone application
1.    Right-click the embedded Mathcad document.
2.    From the drop-down menu, choose Mathcad Object > Open.
3.    Embed opens a Mathcad window with the Mathcad document.
4.    Make the changes you want. For information on using Mathcad, see your Mathcad documentation.
5.    To update the Mathcad document and return to Embed, do the following:
•      Choose File > Update.
•      Choose File > Exit and Return to.
