Rerun from the GUI
From the Set Viewer window in VovConsole, click the run button to request a run. Selected nodes are run, and if none are selected, the entire flow graph is run.
You can also use the keyboard accelerators 'r' and 'R' to request a run. These operations apply to the selected nodes. The lower case 'r' accelerator runs at normal priority, while upper case 'R' requests a high-priority run.
You can get a list of all active run requests by clicking
