List Jobs from Project Having a Given Directory
The CLI Program vst - Vov Show Jobs (aka Show Tools)
The command line program vst lists the jobs from the project that were executed within the indicated working directory, with a default of also having the current environment.
vst: Usage Message
DESCRIPTION:
Show the jobs that have been executed
in one or more directories. By default:
- look at the current directory.
- show only the jobs with same environment as the current one.
USAGE:
vst [OPTIONS] [dir1] ...
OPTIONS:
-help -- Show this help
-quiet -- Be quiet, no explanations
-fast -- (Obsolete option: Maps to -all)
-all -- Show all jobs, regardless of the environment.
Also show system jobs and subjobs.
-long -- Show more information (LEVEL and ENV)
-LONG -- Show even more information
-Output 'format'-- Choose output format
-systemjobs -- Show also the system jobs
-subjobs -- Show also subjobs (components of a bigger job)
-regexp <expr> -- Filter lines with a regular expression
-sort -- Sort lines
Options can be truncated to 1 or 2 characters.
Option -regexp can also be abbreviated to -rx.
EXAMPLES:
% vst
% vst -all
% vst -a
% vst -long ..
% vst -O '@LEVEL@ @COMMAND@'
% vst -re 'ab[cC]+'
Show Jobs for Current Directory and Environment (BASE)
% vst
vst: rule is 'ISJOB==1 ENV==BASE CWD==${SEV_PROJECT_DIR}/common/src/doc_html'
vst: format is '@ID@ @STATUS:10@ @COMMAND@'
00387448 VALID vov ./build.tcl index.tcl
00392249 VALID vov ./makeindex.tcl
00425481 VALID clevercopy work/index.html ../../doc/html/index.html
Show Jobs for Current Directory and ANY Environment
Use option -all or -a to list all jobs regardless of the environment.
% vst -a
vst: rule is 'ISJOB==1 CWD==${SEV_PROJECT_DIR}/common/src/doc_html'
vst: format is '@LEVEL:3@ @ID@ @STATUS:10@ @ENV:8@ @COMMAND@'
2 00587448 VALID GNU vw gcc -c -g strtr.cc
2 00587448 VALID GNU vw gcc -c -g amos.cc
2 00387448 VALID BASE vov ./build.tcl index.tcl
4 00392249 VALID BASE vov ./makeindex.tcl
6 00425481 VALID BASE clevercopy work/index.html ../../doc/html/index.html
