Search Log Files
vovsearchlog searches log files that are daily generated by server, taskers and daemons.
vovsearchlog
Search log files.
vovsearchlog: Usage Message
DESCRIPTION:
Search log files
USAGE:
% vovsearchlog [OPTIONS]
OPTIONS:
-h -- This help.
-p -- Pattern in a regular expression.
-d -- The number of days starting today and backward.
The default is 10 days.
If -s and -e are specified, this is ignored.
-start -- Start time of log files. Format is YYYYMMDD,
for example, 20171020.
-end -- End time of log files. Format is YYYYMMDD,
for example, 20171025.
-f -- Each line starts with filename, otherwise
filename is printed once before searched
contents are displayed.
-server -- Search only in server logs.
-slave -- Search only in logs from vovslave, slave
startup and vovslavemgr.
-tasker -- Search only in logs from vovtasker, tasker
startup and vovtaskermgr.
-daemon -- Search only in daemon logs.
-all -- Search from any logs.
EXAMPLES:
% vovsearchlog -p ERROR -server -d 10
% vovsearchlog -p ERROR -start 20170101 -d 30
% vovsearchlog -p ERROR -start 20170101 -end 2017101
% vovsearchlog -p 000021470
% vovsearchlog -d 2
% vovsearchlog -p "Job.*code" -d 30
% vovsearchlog -p "termination?" -d 30 -tasker
SEE ALSO THESE COMMANDS RELATED TO LOGS:
vovcompresslog, vovloghandler, vovcleanup
SEE ALSO THESE COMMANDS THAT SHOW INFORMATION:
vovjobqueue, vovset list, vovfind,
vel, voveventmon, vovshowconnection,
vovproject list,
vovtaskermgr show
vsi, vls, vst,
vovdoc
