Indoor Penetration Models
Three models for indoor penetration are presented.
- Constant level model
- Predicts a homogeneous indoor level by subtracting the defined transmission loss from the average signal level at the outer walls.
- Exponential decrease model
- Considers the defined transmission loss of the outer walls and additionally an exponential decrease towards the interior, with an attenuation rate depending on the building depth (around 0.1 dB/m).
- Variable decrease model
- Allows to consider a definable attenuation rate (default value 0.6 dB/m) in addition to the transmission loss for the outer walls. In this model the user can modify the exponential decrease of the signal level inside the buildings. The following sample shows the variable decrease model with an indoor attenuation rate of 0.6 dB/m.
