Antenna Settings
ProMan allows also the assignment of time-variant behavior to an antenna. The antenna moves in the same way as the object group does to which the antenna is assigned, or moves as specified along the trajectory to which it is assigned. The trajectory can be edited at this stage.
The assignment of the antenna to a certain group or trajectory can be made in the cell dialog.
Figure 1. Setting the location of the antenna as time-variant in the Cell dialog.
Note: Time-variant settings are available if the time-variant simulation is enabled on the Edit Project Parameter dialog (Simulation tab).
