Specifying the Output Folder for the Prediction Results
Specify the folder for the prediction results to be computed using the dominant path model.
- Click the Propagation tab.
Specify the output folder for the results to be computed using the dominant path model.
- Under Output Directory / Basic Filename for Propagation Results, in the Directory field, change the default PropName to Results\Prop03_DPM.
Figure 1. The Edit Project Parameters dialog - Propagation tab.
