Topics Discussed in Example
Before starting this example, check if the topics discussed in this example are relevant to the intended application and experience level.
The topics discussed in this example are:
  • WallMan
    • Launch WallMan.
    • Import an aerial photograph to create the urban environment.
    • Trace the buildings on the aerial photograph and assign a height to the buildings.
    • Add vegetation to the urban environment.
    • Import the indoor database (3D model of the building) onto the urban environment.
  • ProMan
    • Launch ProMan.
    • Specify the computation method.
    • Launch the Solver.
    • View the prediction results.
Note: Follow the example steps in the order they are presented as each step uses its predecessor as a starting point.
Tip: Find the completed model in the Altair installation directory, for example:
Altair\2021\help\winprop\examples\GetStarted_models\Project2_Hybrid_Urban_Indoor_Scenario.
