Indoor Communication, 802.11g with Multi-Wall Model (COST 231)
The network planning of a local area network in an indoor scenario is investigated. The model is a multi-floor building. The multi-wall model (COST 231) method is used.
Sites and Antennas
There are five antenna sites in different locations in the building. The antennas are installed at a height of 2.5 m. The omnidirectional antennas used in this model are working on different frequencies to minimize interference. The carrier frequencies are around 5.2 GHz.
Air Interface
Computational Method
Results
Propagation results show the power received from each transmitting antenna at every location.
The network simulation also calculates, among other quantities, the minimum required transmitter power, maximum achievable received signal strength, and the SNIR for all modulation and coding schemes used in this model. One result of interest is the maximum data rate, see Figure 1.
The white pixels are an indication that the received power is too low for communication with this standard or that the interference (SNIR) is too high for communication (but that is not the case here since all antennas employ a different carrier frequency).
Figure 1. Maximum data rate for the network.
