Color-Code Objects
You can control the color, shininess, reflectivity, and transparency of individual objects in your scene to color-code the objects in your scene. With the exception of color, these properties do not appear when the scene is rendered.
  1. Select one or more objects.
  2. In the Model Browser, right-click one of the selected objects, and then select Color on the context menu.
  3. To assign a color to the objects, clear the By Layer check box, and then select a Color.
    Note: To return to the default color that is assigned to curves and surfaces in the Preferences, click Default Color.
  4. Adjust the Shininess, Reflectivity, and Transparency of the objects.
  5. Right-click and mouse through the check mark to exit, or double-right-click.
