Learn how to create polygonal surfaces that can easily be converted into NURBS surfaces. PolyNURBS combines the ease
and simplicity of polygonal modeling with the precision and flexibility of NURBS, allowing you to quickly create free-form
solid geometry that is smooth and continuous.
Learn how to add a drawing sheet, create a table, create a view set, create section and detail views, add dimensions
and annotations, and export the drawing.
Learn how to adjust the materials, environment, and properties of objects in the scene to create a photorealistic
image. In addition, learn how to create animations in Inspire Studio.
Create polygonal surfaces that can easily be converted into NURBS surfaces. PolyNURBS combines the ease and simplicity
of polygonal modeling with the precision and flexibility of NURBS, allowing you to quickly create free-form solid
Measure dimensions, analyze curvature, check for continuity and watertightness, analyze the draft, detect undercuts,
assign tags to entities, edit and visualize streamlines as static images or animations, create design iterations on
the fly, and assign variables.
Dimension a line, edge, bounding box, angle, and radius/diameter in order to create objects which must fit predefined
dimensions. You can also insert a general annotation to label the parts of your model.
Tutorial: Basic Drawing
Learn how to add a drawing sheet, create a table, create a view set, create section and detail views, add dimensions and annotations, and export the drawing.
