Troubleshooting
Can't Select Reference Geometry
Condition
I can't select a reference geometry. When I mouse over the reference geometry, it isn't highlighted in yellow, indicating that it's not selectable.
There are two possible scenarios:
Cause 1
You tried to select a solid or nonplanar surface. You can only select planar surfaces as reference geometry.
Remedy 1
  1. At the bottom of the application window, click Select Surfaces .
  2. Select a planar surface. Planar surfaces are highlighted in yellow when you mouse over them.
    Now you can select the planar surface as your reference geometry.
Cause 2
Draft Analysis is turned on.
Remedy 2
  1. Deselect Draft Analysis.
  2. Select the reference geometry.
    Now you can turn on Draft Analysis again.
