::pulse::SetScalarValue
Sets the values of the specified process variables.
- Syntax
- ::pulse::SetScalarValue variable_names variable_values
- Type
- Pulse Tcl API command.
- Description
- Sets the values of the specified process variables. The listed variables must be defined in the process prior to running this command.
- Inputs
- variable_names
- The list of names of the scalar variables for which to set the values.
- variable_values
- The list of new values of the specified variables. The values must be listed in the order corresponding to the list of variable names.
- Example
- To set the value of variable Var1 to 5.0 and the value of variable Var2 to 10.0:
- Version History
- 2021.2
