Altair® Panopticon
Server Monitoring
The Panopticon Visualization Server publishes the following JMX counters:
q  ServerDataRequestCount
q  ActiveDataRequestCount
q  InfoMessageCount
q  ErrorMessageCount
q  ActiveRealtimeSubscriptionCount
q  LoadedWorkbooksCount
q  MemoryStoreObjectCount
q  ObjectCount
These can be accessed through any JMX monitoring toolset, such as Jconsole from the Java Development Kit (JDK).
As a basic configuration:
1.     Download and install Java Development Kit (JDK) http://www.oracle.com/technetwork/java/javase/downloads/jdk8-downloads-2133151.htm
2.     Add the following parameters to your Tomcat:
·         -Dcom.sun.management.jmxremote.port=8855
·         -Dcom.sun.management.jmxremote.authenticate=false
·         -Dcom.sun.management.jmxremote.ssl=false
3.     Open Jconsole. The jconsole executable can be found in JDK_HOME/bin, where JDK_HOME  is the directory in which the Java Development Kit (JDK) is installed.
4.     When the connection dialog opens, you are also given the option of connecting to a remote process.
·         -Host name: name of the machine on which the Java VM is running.
·         -Port number: the JMX agent port number you specified when you started the Java VM (e.g., 8855)
