Trims all leading and trailing spaces from a string.
You can either:
right-click on a Text field
click the drop down of a Text field
then select Clean > Trim in the context menu that displays.
The leading and trailing spaces are removed.
Example: Description is the original column and Description Trimmed shows the trimmed data.
