Time Window Calculations
Time Window calculations allow new columns to be created that are based on a defined time window.
As a consequence there are several additional functions:
Functions |
Description |
COUNT_TIMEWIN |
Like SUM_TIMEWIN, but simply returns the number of time slices between the defined time window, that have non-null values. |
CUMSUM_TIMEWIN |
The cumulative sum of Time Series value between start and end times. Alias for SUM_TIMEWIN(“Measure”,TimeWindowStart,Now). |
LOOKUP |
The value of a Time Series measure at a specific time. |
MAX_TIMEWIN |
The maximum value between the start and end times. |
MEAN_TIMEWIN |
The mean value of the Time Series between the start and end times. |
MIN_TIMEWIN |
The minimum value between the start and end times. |
PRODUCT_TIMEWIN |
The product of the Time Series values between the start and end times. |
STDEV_TIMEWIN |
The standard deviation of the time series between the start and end times. |
STDEVP_TIMEWIN |
The population standard deviation of the time series between the start and end times. |
SUM_TIMEWIN |
The sum of Time Series values between start and end times. |
And three additional measures:
Measures |
Description |
SnapshotTime |
The time slice at the Snapshot Time. |
TimeWindowEnd |
The Time slice at the end of a time window. |
TimeWindowStart |
The Time slice at the start of a time window. |
When using Time Window calculations, fields referenced by the calculation should be enclosed in double quotes and NOT square brackets.
For example, using the Time Series column PRICE, the following calculations can be created:
Difference Between Start and End of Time Window |
LOOKUP(“PRICE”,TimeWindowStart)-LOOKUP(“PRICE”,TimeWindowEnd) |
Time Window Maximum value across |
MAX_TIMEWIN( “PRICE”, TimeWindowStart, TimeWindowEnd ) |
Time Window Standard Deviation |
STDEV_TIMEWIN( “PRICE”, TimeWindowStart, TimeWindowEnd )
Variance since Time Window Start |
( [PRICE] - LOOKUP(“PRICE”,TimeWindowStart) ) / LOOKUP(“PRICE”,TimeWindowStart) |
