Table Settings
You can define the table settings of the data you opened to create the Workbook.
Defining the Table Settings
Click on the Settings link at the bottom of the middle window in the Data screen.
The Data Source Settings panel displays.
This allows you to:
Change the Data Source configuration
Transform Data
Define Output Columns
Click OK to continue.
The Data source can still be changed by clicking and expanding the Data Plug-in Settings tab of this dialog.
