System Hardware Requirements
Hardware requirements are intrinsically linked to the data environment Panopticon Designer (Desktop) will be deployed into. Consequently it is difficult to provide sizing, without understanding the use case, data size, data throughput, and end client population. The following information is consequently included as a guide, and the exact hardware requirements should be determined on a case by case basis.
Additionally, the requirements for data caching can significantly change the hardware specification. Panopticon Designer (Desktop) supports the Result Set Cache layer. It is used to minimize end user interaction latency when accessing underlying slow data sources. It caches the results of queries, minimizing database load, and is optional.
