Removes the sequence of characters from the values of the column you apply this operation to.
You can either:
right-click on a Text field
click the drop down of a Text field
then select Clean > Strip in the context menu that displays.
The Strip dialog displays.
Enter the sequence of characters you want to strip.
Click OK.
Example: Account Number is the original column. The Strip operation was used to remove the dash “-“ to produce the resulting values in the column Account Strip.
