Sequential Color Palettes
Sequential Palettes use a two color gradient between a minimum and a maximum value. Numeric column containing only positive values default to a Sequential Palette using the Yellow Red color palette.
In this case the range Mid point is disabled and the Min and Max points are populated with defaults from the data set.
