Displays all the changes made in the data sources. You can Apply or Unapply changes.
NOTE: Starting version 16.1.0, review Change operations is no longer displayed. It is however, still available and supported on older workbooks with data prep operations definition that will be opened in the current and later Panopticon Designer (Desktop) versions.
Click Review Change Operations . The list of changes done in the data set is displayed.
Hover on a change the Unapply button displays.
Click Unapply. All of the operations are unapplied starting from the one you selected.
Hover on an operation you want to re-apply and click Apply.
Click again to hide the list of change operations.
