Percentile Range Filters
Percentile Range Filters let you filter based on the data distribution, whether quartiles, quintiles, deciles or percentiles.
Select the range for the Percentile Range Filter by grabbing the handles at either end of the filter and moving them to the desired setting. The legend for the filter will display the values for the high and low points you have selected.
You can also directly enter the percentage values you want to use in the filter. Click on the legend and enter specific values with accuracy of up to two decimal points.
You can cross the handles so that the extremes (distribution tails) at each end of the range are included in the dashboard. This filters out data in the middle of your data set (the range between the crossed handles) and lets you focus on the outliers.
