Parameterization of Connection Settings for Data Connectors
Connecting to data connectors typically requires application login. To be able to connect, you may need to enter the following information, depending on the connector:
Host Name
Port
Server Name
User ID
Password
Database
These information are then stored in XML files detailing user & group permissions in workbooks. To secure data access and avoid storing connection information in the workbook, it is recommended to parameterize these fields in connectors.
NOTE: Parameterization is supported in Progress DataDirect connectors and most of the other data connectors.
In the Parameters section under the Data Table in the Edit Data Table window, define the connection settings you will use for the connector. Such as the following:
Host
User
Pwd
Server
DB
Port
For example:
Click the
of the data source.
The Connection Settings dialog
of the data source displays. -
Parameterize the entries in the dialog.
For example:
Click OK.
