Parameter Assignment Scope
Parameter assignment scope is controlled through the workbook properties.
Select the menu: Workbook >Properties
The default parameter assignment scope is set to Workbook. This can be modified when required and be set to Dashboard:
When set to Workbook, a parameter when updated, will update all dashboards within the workbook.
