PDF Settings
The PDF output settings are defined on a workbook basis.
Setting PDF Ouput
Within the Panopticon Designer (Desktop) use the menu: Workbook > PDF Settings.
The PDF Settings dialog displays.
Configure the following PDF output properties:
Page Size
Orientation – Landscape or Portrait
Dots per Inch (DPI) – The higher the number of the dots, the higher the quality of the print.
Dimensions – The output resolution (Height X Width) based on the specified DPI, paper size, and resolution.
Header and Footer
Page Margin
Click Restore Default PDF Settings to revert to the default properties.
Click OK.
