Adding Numeric Sign Bucketing
Numeric data is represented as a continuous set of values in displays and filters. Sometimes it may be necessary to divide the data into positive and negative subsets. This can be achieved with Sign bucketing.
Right-click on a Numeric field, and select New Bucketing Column…
The Create Bucketing Column dialog displays.
Select Bucketing Mode to Sign, and complete the Name, format, then click OK.
Once added, the new sign bucket column will appear in the output data schema.
