Importing/Merging Workbooks
Existing workbooks can be imported into an open workbook, merging the two together, and consequently allowing easier collaborative working.
You can either:
Select Import Workbook from the File menu item.
Browse to the required workbook, and click Open.
Dashboards and data tables from the selected workbook will be added to the open workbook. If a dashboard or data table with the same name is already present the import operation simply changes the name of the imported dashboard/data table.
