Features Added in Version 13.6
New Vertica connector
Logging configurable in Visualization Server for .NET
Ability to maximize Connectors window
New Iframe Part visualization
Security plugin for the Visualization Server for Java
Implementation of the Backend Server Managers by using interfaces in the Visualization Server for Java
Ability to terminate the session of a user after a client logout request in Visualization Server for .NET
Ability for the JSON connector to:
handle no array data
handle arrays within arrays of data
For the JSON, Text and XML connectors:
clicking the Tab key performs desired action (i.e., go to the next field box or hit a button)
set the Text cursor on fields box and allow necessary parameterization
ability to set custom HTTP Header
ability for the HTTP URL to include user agents
The Headers value in the XML connector can be parameterized
The new HTML connector has a Web URL option where the entered URL can be grabbed and parameterized
Ability to retain authorization settings when republishing local workbook
Use of the Tomcat JNDI Realm as Tomcat’s built in the LDAP Authentication mechanism with the Visualization Server for Java
Text option now available in the JSON and XML connectors
Improvement in the Applications dropdown for the Splunk connector
